Efficient farming in PoE 3.26 requires not only a strong build, but also a strategy that keeps your momentum going. One of the
PoE Currency best ways to maintain high efficiency is to chain maps with purpose and direction.
Choose one or two maps that complement your build’s strength. Fast-clearing builds do best with open layouts like Strand, Dunes, or Toxic Sewer. Tanky builds can handle more complex layouts like Crimson Temple or Mesa.
Use your favorite map system to boost drops. Once your Atlas passive tree is optimized, select favorite maps so you can consistently sustain your preferred layout. This minimizes downtime and increases farming efficiency.
Incorporate scarabs like Ambush, Harbinger, or Expedition to multiply monster density and reward nodes. Combined with strongboxes and shrine passives, these mechanics increase your chance of earning Exalted Orbs per run.
Always run maps with full completion bonuses (awakening objectives and voidstones active). Higher-tier maps provide better loot potential, including more opportunities for rare drops like Exalted Orbs.
Stockpile multiple maps of the same tier and layout so you don’t need to waste time rolling new ones constantly. Prepare them with consistent mods that your build can handle, such as “more monsters,” “extra projectiles,” or “additional rare packs.”
Use Evasion or Dodge-focused flasks and phasing to streamline your movement between packs. Movement speed
PoE 1 Currency matters just as much as raw damage when trying to clear efficiently.
Implement a loot-filter designed to highlight Exalted Orbs and filter out clutter. Time saved on pickups translates directly to more maps run per hour.
Map chaining isn’t just about repetition—it’s about refining your strategy over time. As you streamline your process, your orb-per-hour rate will increase significantly.
