Winning at
block blast is simple, but you need to think because this is an attractive puzzle game that combines flexibility and tactical thinking. To win, players need to master some basic strategies.
First, carefully observe the board to identify blocks of the same color. Prioritize clearing large blocks to create more points and activate combos. Clearing multiple blocks at the same time not only helps you score points but also makes the board more open.
Second, plan before moving. Avoid moving randomly, as this can cause you to miss the opportunity to clear multiple blocks. Try to create combo chains to maximize your score.
Finally, use support items wisely. These items can help you clear multiple blocks at the same time or change their color, creating better opportunities for the next turns.
