In Path of Exile 2, the Huntress class boasts some of
POE2 Currency the most explosive and elemental-heavy gameplay, thanks in large part to her unique passive skill: Infuse Weapon. Exclusive to the Amazon Ascension, this powerful mechanic is unlocked by taking the Elemental Infusion node, which only requires two Ascension Points—making it one of the most accessible enhancements for early-game Huntresses.
To acquire Infuse Weapon, players must first complete either the Trial of Sekhmas or Trial of Chaos, challenges specific to the Huntress class. Upon completion, players can select the Amazon Ascension, which opens the path to Elemental Infusion. Because only two points are required, players can begin utilizing this ability after completing even the lowest difficulty version of the Trial.
A Passive Powerhouse with No Skill Gem
Unlike active skills that require manual input via hotkeys or right-click, Infuse Weapon is a passive skill—meaning it operates silently in the background. Once activated, it requires no micromanagement. This also means that there is no skill gem associated with Infuse Weapon, and as a result, other classes cannot use it—it is a true hallmark of the Amazon Ascension.
Despite being passive, the mechanic behind Infuse Weapon is layered and strategic, requiring a proper understanding of the elemental charge system and projectile-based gameplay. The Amazon doesn’t need to press buttons to wield this power; she needs to build around it.
Understanding Elemental Infusion: The Gateway to Power
The Elemental Infusion node grants access to Infuse Weapon and defines how it interacts with the Huntress's elemental charge system. When a charge is consumed to trigger Infuse Weapon, it generates specific elemental infusions:
Energy Charge ➝ 2 Cold Infusion
Endurance Charge ➝ 2 Fire Infusion
Fury Charge ➝ 2 Lightning Infusion
Once active, the Infuse Weapon effect causes non-melee projectile attacks made with the infused weapon to consume the infusion, resulting in a massive explosion at the projectile’s impact point. This explosion serves as both an area-of-effect (AoE) damage boost and a visual spectacle, making the Huntress's ranged attacks even more deadly.
Triggering Infuse Weapon: The Step-by-Step Breakdown
The activation of Infuse Weapon isn’t arbitrary; it requires a specific sequence of in-game events:
Generate a charge using a skill like Cull the Weak or by fulfilling conditions tied to nodes like Battle Fury.
Consume the charge with a skill that uses it—such as Lightning Lance. Doing so triggers Infuse Weapon and grants elemental infusion based on the type of charge used.
Fire a non-melee projectile (like Twister Lance), which consumes one of the active infusions, causing an explosive hit at the end of the projectile’s flight.
Infusions last for 15 seconds and a Huntress can maintain up to 6 of each type simultaneously. This means managing your charges and timing is critical to maintaining uptime and maximizing explosive output.
Best Skills to Trigger Infused Weapon
The Huntress has several potent tools in her arsenal that pair perfectly with Infuse Weapon. Each of the following skills not only consumes the right charges but also fulfills the condition of being a non-melee projectile:
Lightning Lance
Explosive Lance
Storm Lance
Glacier Lance
Twister Lance
Each of these “Lance” skills offers a different elemental flavor, allowing the player to tailor their build around specific infusion types—be it Cold, Fire, or Lightning.
Efficiently Generating Charges
The backbone of the Infuse Weapon mechanic is the generation of elemental charges. One of the most efficient methods for acquiring Fury Charges is through the Battle Fury node on the passive tree. This node grants Fury Charges when the Huntress Electrocutes, Freezes, or Cripples an enemy.
Among these, Electrocute stands out, especially when paired with Kitoko’s Current, a unique pair of gloves that greatly enhances your chance to apply Electrocute. Since Lightning skills are frequently used in Infuse Weapon builds, this synergy offers seamless charge generation and infusion gain.
For those pursuing a Frozen Huntress archetype, an additional Resonance Node can convert all Fury Charges into Energy Orbs, enabling a Cold-only infusion setup. This conversion allows players to fully commit to Cold-based builds, especially when leveraging Glacier Lance or Twister Lance for devastating AoE bursts.
Infuse Weapon may operate passively, but its impact on gameplay is profound. As a Huntress with the Amazon Ascension, this skill opens up a new layer of explosive elemental damage and powerful ranged combat. Whether you prefer lightning-fast Fury Charge generation or cold-focused control, mastering the infusion system is key to unleashing the true potential of
cheap POE2 Currency the Huntress.
With thoughtful build planning and charge management, Infuse Weapon turns every projectile into a potential mini-nuke—making enemies think twice before standing still.
