Tämä alue on tarkoitettu vain tekniikkaa käsitteleville aiheille, muut aiheet kuuluvat yleiskeskusteluun!
Tällä alueella keskustellaan tekniikasta yleisellä tasolla. Huomaathan että tekniikkakeskusteluille jotka koskevat vain kaksi- tai nelitahtisia malleja on omat alueensa!
Why is My Dryer Running But Not Drying?
12.5.2025 1:52
I’ve tried everything to fix my dryer, but my clothes still aren’t drying properly. I’ve replaced the heating element and checked the lint filter, but it seems like the problem is still there. Could the vent be clogged?
Re: Why is My Dryer Running But Not Drying?
12.5.2025 1:59
Yes, a clogged vent is often the main culprit.
12.5.2025 3:43
A clogged dryer vent could be the reason why your dryer is running but not drying clothes properly. I had the same issue, and it was driving me crazy! It’s one of those things that you don’t think about until it starts affecting your dryer’s performance. The airflow becomes restricted when the vent gets clogged, which causes the dryer to overheat and not dry clothes efficiently. In situations like this, I highly recommend calling a https://comfortclean.com/dryer-vent-cleaning/ dryer cleaning service to get the vent professionally cleaned. They have the tools and expertise to remove all the lint and debris that’s causing the blockage. It’s a quick fix that can save you a lot of hassle and keep your dryer working like new. After I had mine cleaned, I noticed an immediate improvement. Not only was my dryer drying clothes faster, but it was also using less energy. It’s such a simple thing to check, and it makes a huge difference.
