19.3.2013 21:54
19.3.2013 22:02
19.3.2013 22:37
strobovalo12 kirjoitti:onkos kellään tietoo mistä sais tiger rs-800 tehoputken? näin että turkista sais niitä mut eikö mistää lähempää? jos kellää ois tietoo/kokemusta nii ihmees vastailkaa tai pistäkää linkkii sivuista!
SMink kirjoitti:Olihan ne joo vähän korkeammat hinnat kun muistin. Siitä infoa:
Dear Sir,
1-)
You can use the full system without a power commander.The power commander is needed for bigger motorcycles after changing all of the pipes to titanium.Our pipes are titanium they are stainless steel.So the weigt change will not be so big.The full system is made because the original pipe is very short and does not go all way to the back.Not to make a weight reduction.
Because the change of headers pipes of big bikes reduce the weight tremendously the engine needs a power commander to recalibrate the air/fuel injection for the new weight but the 125 cc engine will not have any relevent change in fuel consumption or weight with new exhaust.The power commander is used for engines 1000 cc and more.The headers pipes of big bikes have 4 manifold extensions and they are very heavy.When the pipes are changed to titanium it makes a huge change.But when you change your exhaust to our exhaust the steel pipes do not have such a big weight change because its just a single line pipe that weigs around 1,5kg.
So dont worry about power commander.
2-
Our exhaust is also a plug in exhaust that has same convenience as installing a slip on.The only difference is you plug the pipe to the engine instead of plugging the silencer to the custom pipe.The stock pipe is not suitable for installing a slip-on silencer so it must be changed and it is very easy to do this.The slip on and full system price is same because the only difference is a 1,5kg steel pipe.It is not a titanium full system ,it is called full system because it includes a pipe that is connected to the engine in order to use a silencer.
3-
We will send it to your home address and we will write sample on the invoice and we can show the price very low so you wont have a problem with customs in finland.We always do it like this to solve this problem.
http://www.tigerexhaust.com/motor-model ... r_125.html
this link has 3 models suitable with wr 125 which one would you like?
RS-700 s.steel 170 Euro
RS-780 s.steel body carbon cap 235 Euro
RS-800 full carbon 395 Euro
The shipping to Finland will be 70 Euros
So the total price will be Silencer fee + Shipping fee
If you pay by paypal I can make a 5% discount for you because the service fee is lower than bank or western union.
If you have any question please dont hesitate to ask.
Best Regards,
___________________________
Murat CAM
Tiger Exhaust Systems
Int. Research Department
20.3.2013 11:49
EeeGee kirjoitti:Mistähän johtuu et ku vaihteen pistän sisää nii weera sammuu ja moottorin vikavalo alkaa vilkkumaan? Pyörä on nyt aikasemmi seissy pari päivää ulkona, ku akun takia ei aikasemmi lähtenny käyntii, nytkun sain sen akun ladattua niin ilmeni taas tää ongelma
20.3.2013 11:54
20.3.2013 13:36
20.3.2013 14:46
20.3.2013 14:48
LeKe96 kirjoitti:strobovalo12 kirjoitti:onkos kellään tietoo mistä sais tiger rs-800 tehoputken? näin että turkista sais niitä mut eikö mistää lähempää? jos kellää ois tietoo/kokemusta nii ihmees vastailkaa tai pistäkää linkkii sivuista!
Ei oo kokemusta nuista putkista, mut toivottavasti tästä viestistä on jotain apua.
ps. Älä välitä tosta kun selittävät et ei tarvii ruiskuu säätää, kun putken paino ei vähene.Tiiä mikä aivopieru turkkilaiselle tullut.
Dear Sir,
1-)
2-
3-
Best Regards,
Murat CAM
20.3.2013 15:21
Yaaamaha kirjoitti:Kyl toi ennemmin viittaa siihen seisontajalan anturin jäätymiseen/hajoamiseen...
23.3.2013 22:43
24.3.2013 0:42
24.3.2013 1:19
SMink kirjoitti:tanaan vaihdoin 520 jakoisiin ketjuihin ja 12-48 rattaisiin. aiemmin oli vakio ketjut ja rattaat. onko muutosta tulossa nyt kun valit lyhyemmat. olenko btw ainoa jolla tama mobiiliversio lagaa eika erikoismerkit tai 'a' kirjain toimi
24.3.2013 19:43
24.3.2013 20:11
24.3.2013 20:45
